Anyone running these headlights?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Yes people have, yes they are JUNK. They will be worse than your OEM headlights. People on here have had them and simply thrown them away
Do a search on here rand you'll see
Smokin139
Smokin139
That's what I assumed, they look nice but unless the projectors are good. It's not worth it. What about retro fitting a good projector into these headlights?
I want to have a different DTRL other than the low beam
NathanJax
Vacation Nathan
Administrator
Jax, Fl
I don't know if anyone has tried yet. The OEM Yukon headlights look so good with the projector in the middle of the headlight.
Not sure about the DRL
Smokin139
Smokin139
I might get something like these and swap out the projectors. It has what I want in a light and I can make it just as bright as I would in a Yukon headlight.
But it's hard to pass on factory quality these days . I need to do more research
Thanks!
wikizards
I have had luck with my SPEC-D headlights. They plug right in but the halogens can be swapped out for after markets hid's (I am using a brand from amazon called Innovited), you just have to find a nice spot for the ballast to sit tightly. I have the only 2009 Yukon with HID's in my area, I've had other Yukon drivers flash me at times. Will post pictures. The whole set up was less than $300 all in (without counting the time spent going under the fender to release the headlight, long process but once you do it, next time is a piece of cake)
the_wood
TX
Agreed! I tried a few similar setups like this in the past and wound up getting a set from Blackflame Customs, which I happen to be selling. Depending on what you're looking to spend, these could be right for you! Below is the link to the exact build - I only used the setup for approximately 2 months, about 2500 miles total. Let me know if you're interested! Shoot me a pm if you're interested.
http://blackflamecustoms.com/2008-gmc-yukon-oem-chrome-hid-projector-retrofit-conversion-headlights/
hillcreekfarms
