Anyone use ridetech?
Nortex
Im looking for a bolt on air ride kit. Id like to be around a 4/6 drop and able to raise to stock. Any other kits out there?
Sent from my LGL33L using Tapatalk
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes i have and the oem tbss bags sit lower and are a bolt in deal. I posted up about this few times before
you will need
tbss oem bags (aftermarket ones are to wide they rub frame)
5/32 to 1/4 inch push to connect fitting (2 of them)
5/32 line about a foot so you can make the connection
airlift 72000 is what i set up on customers trucks
you will need the djm rear hardware kit with extenders so lower a arms dont bind when laid out
also spohn rear bar kit because when you lay it on frame axle gets pushed way forward and into the trans
oh you can tow 6500 lbs with the tbss bags
witty_name
