bsamoul
Hoe Enthusiast
It looks pretty cool, it displays
Vehicle Speed
RPM
Fuel Consumptiion
Engine Coolant Temp
Fuel Pressure
Calculated Engine Load
Throttle Position
Intake Manifold Pressure
Air Intake Temp
Timing Advance
Mass Air Flow
Fuel Level
Barometric Pressure
EVAP System Vapor Pressure
Fuel Trim
Boost
All wirelessly with the $150 cord, and the app is only $40. So basically, I'm wondering if you think about 200 is worth it to display that data on your iphone. It also can clear your CES light codes too for smogging. I already have an Actron scanner that does this too, but this has graphs and does data logging.
Anyone have any ideas/input about it?
Vehicle Speed
RPM
Fuel Consumptiion
Engine Coolant Temp
Fuel Pressure
Throttle Position
Air Intake Temp
Timing Advance
Mass Air Flow
Fuel Level
Barometric Pressure
Fuel Trim
Boost
