BlueTahoe2001
If you're building a simple enclosure, use MDF or birch for the flat spans and then you can use fiberglass to get the contours you want on the baffle. Try to restrict fiberglass usage to contours and irregular shapes. When using MDF for enclosures, you can brush on a thin layer of fiberglass resin on the inside panels to completely seal the enclosure. MDF is still porous and can leak air. A layer of resin will seal it.
Cool, So in a nut shell Fiber Glass is a no-no for flat surfaces? Contours and Irregular shapes only?
Also, Just to double check, I am building a box that is 12x12x9" Is that to much flat surface to use fiber glass. What is the max flat surface you would use FG on when still trying to achieve strength?
The reason I ask is because I would like to get the finish of FG on the simple box I am building. Just to give it a custom look.
