Anyone using DDM Tuning lo/fog HID post here, i need some help
Slow5.0
Missouri
Ok im about to order HID kit for my Lows anf fog light, i talked to DDM they said that they dont have that relay kit to hook up high beams? ??
Anyway questions about lo beams are
1. Should i get slim or raptor ballast
2. 55 or 35watt ballast
3. Do i need error eliminator for lows
Questions about fog lights are
1. Slim 35 or raptor 35watt
2. Do i need error eliminator for fog lights
Also please post your setup specs
Thank you
1sikyukon
SFV, CA
Thank you
I have been using DDM for as long as i can remember for all my cars and friends cars. They offer great products that are both priced right and quality product. The relay they are talking about is for yukons. They have the high and low beam both in the same bulb so they offer an H13 hid kit with that same feature that requires the relay inorder for the bulb to adjust to a higher postion when u pull on the high beam lever. Ill be honest i have this feature on my car and I NEVER EVER use it HIDS are bright as hell as is and its useless.
1. Should i get slim or raptor ballast--> SLIM RAPTORS ARE MORE FOR OFFROAD VEHICLES. SLIMS ARE PERFECT FOR ARE CARS AND MOUNT CLEAN.
2. 55 or 35watt ballast--> THATS REALLY YOUR OWN PERSONAL CHOICE I ALWAYS PURCHASE 35 THEY ARE BRIGHT AS HELL AND USE LESS POWER I FIND NO REASON FOR THE 55
3. Do i need error eliminator for lows--> NO ERROR ELIMINATORS ARE MORE FOR EUROPEAN CARS (BMW, VW, BENZ) OUR AMERICAN MADE CARS DONT REJECT HIDS.
1. Slim 35 or raptor 35watt--> SLIM AS STATED ABOVE
2. Do i need error eliminator for fog lights--> NO, AS STATED ABOVE
GOOD LUCK HOPE THIS HELPED!
emann_01
low beams - 35w raptor kit, no error eliminators....55w with stock headlights will be extremely bright and you will get flashed for your highs being on all the time...also, 35w will match the fogs better....plenty of room to mount a regular ballast under the hood...save the extra 10 bucks
fogs - 35w raptor kit, no error eliminators...same reasons as above
JMHO..hope it helps
Jcombs
