Appocs 07 Hoe Build Thread
AppocAlexx
AppocAlexx
Darth Appocalexx
Abilene TX
With how the front ends differ I'm not sure if the grille guard will look right on the Sierra. Wife still wants it off her Tahoe so i will have to get it off and test fit to see how it will sit with the front end lines of the Sierra. Maybe it won't look to bad.
AppocAlexx
AppocAlexx
Darth Appocalexx
Abilene TX
Only other I forgot to mention was I had to do some parts replacing a couple weekends ago. Also I have never see an orifice tube like this one that was in the Tahoe looks kind of crazy.
kwOH
Banned
Only other I forgot to mention was I had to do some parts replacing a couple weekends ago. Also I have never see an office tube like this one that was in the Tahoe looks kind of crazy.
What exactly is this and why did you have to change them?
Sent from iPhone 7 plus using Tapatalk Pro
AppocAlexx
AppocAlexx
Darth Appocalexx
Abilene TX
Did an A/C kit that replaced the compressor, accumulator, and orifice tube. The orifice tube is that thing we r holding and go inside the tube that goes back to your compressor and basically acts as a filter for your freon.
Also did the K&N drop in filter and oil change with some BGs additive.
PG01
Up here to the right
That orifice tube is normally white, well they used to be anyway, i think its neon green because someone put the dye/sealant for a/c system leaks into it. I just watched the mechanic at work put some a/c stop leak stuff in a new 2016 chevy van that had a leak...and its neon so you can see where it leaks..
AppocAlexx
AppocAlexx
Darth Appocalexx
Abilene TX
The color I can understand I mean how it has the plastic coral looking stuff most orifice tubes have a mesh type filter
MstngCbrSVT
