Are DRL's and turn signals interchangeable?
JesusArTorres
Tulsa, OK
The answer is in the picture, I know. But I just want to make sure with anyone who knows this...
DRL is 4157K and turn signal is 3157A. I want to use the entire bottom lamp as a turn signal so I need a 4157 in Amber, which I cannot find.
So I was wondering if instead I could plug in an amber 3157, just like in the turn signal?
YukonXL04
The Riverboat
Arlington, TX
Technically yes you can. However you will only have a single brightness due to the harness and plug in the drl. If you swap the plug and wire it into your turn signal wires then yes it will work. I believe the parts stores sell that plug with wire pigtails that you could use.
JesusArTorres
JesusArTorres
Tulsa, OK
You're saying it's best if I swap the DRL harness with a turn signal harness?
Now that I think about I had to do that anyways since the DRL harness will go to the top lamp on the headlights I want.
I'll have to piggyback an additional turn signal harness onto the existing one. May that be a problem?
YukonXL04
The Riverboat
Arlington, TX
Yes I am saying to splice a turn signal harness into your existing harness for them to work properly as a turn signal.
YukonXL04
The Riverboat
Arlington, TX
It should. Just try fitting your current signal socket into the drl portion of the lens. I'm pretty sure it will fit
scoobydont
