are my bars cranked?
durty
How can I tell if the torsion bars are cranked up any? The back sits higher than the front and it looks to have a 2" block out back.
Can I crank the bars enough to level it? I can put a jack under the front and it travels enough to level it, back measure right around 38.75 with a 285 on it, and pretty sure the front was right around 37.5
Wakinvol
East TN
if you are 2007+ you don't have any bars to crank. What year is your ride?
Zed 71
Pacific NW
IMO your t-bars are cranked already based on having a 2" block in the rear and the height differential. Check with the OBS section to confirm.
D
durty
Well I crawled under it and the bolts are almost bottomed out, im wondering if the bars are gettin worn out
Will aftermarket keys give me lift even if the bars are worn?
Zed 71
Pacific NW
If you have leaf springs in the back then I am assuming you have an OBS truck. Do you know the history of the truck (usage), and of course mileage and age. IMO your torsion bars are worn and cranking the keys will not help. Confirm with the guys in the OBS or NBS forum sections.
davidmakey230
