Arnott conversion bypass install
I looked at Arnotts instructions and couldn’t believe their pictures didn’t clearly show the pin outs or even mention the colors of the wires.
R
rollinjoy
Instructions from arnott says B-8 pin but there is no b-8 pin being used on my pink connector.strange. Only pins used on B side are 1,3,4,5,6.
1-lite blue/white stripe
3-lite blue
4-gray
5-brown
6-white
3-lite blue
4-gray
5-brown
6-white
You’re looking at the connector from the wrong end. I believe you’re looking at it from the rear where the wires exit. If you look at it from the front of the connector it will make sense. That’s what the picture in the diagram shows- at the upper right is the 3 dimensional picture showing the correct orientation of how you’re supposed to be looking at it, then below is the picture showing PIN numbers. I imagined you looking at the back side and you’re looking at it upside down and backwards because then A12 is what you think is B1 ( lt blu/wht) and what you think is B3 is actually A9 (grey which can look like lite blue) etc. Try again, looking at the front of the connector and oriented like the picture.
Ok good, glad you figured it out. That’s why I included the pictures.
steelersallday30
Found the controller. Thx. Now does anyone know Which one is pin D and pin E on the gray connector. And pin B-8 on pink connector. Those are the 3 wires I need to splice into
Hey brotha I have a 2003 Yukon xl Denali was the air control module there in the passenger side? Was it easy to install? And is it easy to take off the panel? I can’t find video any where
wjburken
Eastern Iowa
The link to the video is in post #2 of this thread. Worked for me just now.
steelersallday30
I installed the Arnott Autoride conversion kit on a 2002 Yukon Denali xl. Now I can’t find where to wire the bypass module for the kit. Where is the air suspension controller located? Instructions say it’s in rear right side of cargo area. I can’t find
Hey brother how did the conversion kit work out I bought part number c-2667 I’m hoping it works well and is a good product
domino2jel
