NoNamesLeft
What a pita to compare all the different scanners. This is the best explanation of the various Autel lines (MS, MK, MX, etc) that I found: https://medium.com/@obd2gate-com/differences-between-autels-diagnostic-scanner-series-8c01f32124d1
I'm waffling between the new MS 906 Pro TS and an older model MS 906 TS. Main reason for the purchase is for the 2013 Tahoe. I'm assuming there isn't much difference between the two for the Tahoe. The MS906TS is less expensive and comes with a battery tester that should be useful ($300 if bought separately).
Some questions:
1. Do the Autel scanners continue to work indefinitely or do you have to update them every year for them to keep functioning? That would be a deal breaker.
2. Do the updates bring the scanner's capability up to or near the current model scanner?
3. For those that have used the Autel scanners, any tips or things to watch out for?
Reading the hassles with the VXC and the questionable Tech 2 clones (and the sketchy websites that sell them) I'm only willing to consider a real Tech 2, which are selling for $1,200+ on ebay. Once spending that kind of money might as well buy a scanner that can do other manufacturers as well, is that wrong thinking? Right now we have three older GM vehicles that a Tech 2 would work on. We have a few newer other makes as well where the Autel should be useful.
Any comments welcome.
Some questions:
