Auto air ride adjustment after lowering
krt
So Cal
So I just install a belltech 2 spindles and 3/4 5305 springs on my 06 yukon xl. It has the auto air ride and I changed to the shorter rods on the end links. The 1" spacer is not installed.
So when I first put it back on the ground with no air in the shocks, (I had the compressor unplugged) it sat really low. After hooking the comp up and filling the shocks it came up pretty far, and the comp seems to run longer now when I start the truck up each time. I tried making the rods as short as they would go.
My questions is how much load should be on the air shocks? It seems like they are filling a lot more and raising the back more. I always thought that the springs should carry the load? My only ideas at the point are try shorter rods with the end links or install the 1" spacer?
thoughts anyone? thanks
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
are you using the shock extenders that come with the kit?
krt
krt
So Cal
Yes, and the shocks / compressor were new from Arnott about a year and half ago.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
sorry buty how long is it from the center cap/cap on the autoride rods?
krt
krt
So Cal
Just under 3" inches, maybe 2 7/8? I can't make it any shorter they are all the way in. I could buy some rod stock and make my own.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
10X24 machine screw cut it to 2.5 inches long.
Did you get the kit from me? Not sure if you were the same guy that called me from down south and had issues installing the rear springs
krt
krt
So Cal
Ok Tony, I will give that a try.
No I got these items locally off craigs list. The spindles from a guy that wanted his truck lower and replaced them with a-arms and another guy sold his rig before installing the rear kit. Lucky on both finds I guess.
I will be order the DJM shorter sway bar end links from you though.
krt
krt
So Cal
Well shorting the rods so the end links are at 2 and 3/4 on center worked, (thanks Tony). It now sets at ~34" vs 35", no air it was 33 and 1/2. The front sets at ~33 and 1/2. It's going to need the free travel mod, not much space between the shorter bump stops and the axle. Here are a few pics:
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
If you do the free travel mod before you do the links be aware the swaybar will slap the panhard bar bracket on dips
krt
krt
So Cal
Thanks Tony... I will be in contact soon for the sway bar links and bump stops.
RepublicanRebel
