Auto mode turns on 4x4 mode
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Great info, but are you sure that the 246 is for GMT900s? Everything I'm seeing is that it's for older, pre-2006/7 vehicles.
It's not but the operation should be similar.
EDIT:
Here are the TC models for the NNBS -
And here is some info -
Looks to operate about the same to me.
jwth
Michigan
wow I feel so foolish
I have driven my 2003 in auto 4x4 on the e way and in the city for 230,000 miles without replacing the front dif.
not in summer unless heavy rain, but for sure from the beginning of november til may.
no problems and no noises
maybe I should have the dif replaced anyway.
George B
¯\_(ツ)_/¯
Can't hurt... It's only money.
Geotrash
Dave
Richmond, VA
Funny you should say that. 230K is about where the front diff on my 2002 shit the bed. The PO drove it in auto mode for its whole life before selling it to me. Driveline shop told me not to run it in auto mode any more. Lol.
I suspect maybe the problems arise when people run mismatched tires/tire pressures causing the clutch pack to engage more than it otherwise would, wearing out bearings and such faster.
George B
¯\_(ツ)_/¯
Like I said earlier the only difference between the AWD and part time case is the passenger side output shaft with the AWD being solid and the part time having a disconnect. Running that differential engaged in itself will not cause an issue.
Fless
Super Moderator
Elev 5,280
^^ This. The wheels will roll the diff all the time. The only time it engages with the front propshaft is when the front diff actuator is called for during rear wheel slippage. Hence "AUTO."
ford_siesta
