Yes to a certain extent, until the springs and/or shocks stop it from going lower. To find out approximately how much your (autoride) air shocks are jacking it up, just remove one of the air lines and let the air out of the system. You just pull the metal clip and pop the fitting off. Keep in mind no matter how short the links, it will still air up a bit, maybe 1/2". You can get shock extenders too for around $40-$50, they mount the shocks so they allow it to go a bit lower. As far as shorter links, you can either use all thread or just buy bolts and cut the heads off. The size is #10 x 24 and start with 3" length, shorten as necessary.Mark. are you saying that if I replace the links that I can lower the back of my Tahoe LTZ without doing anything else? If thats the case, would you happen to know where I can buy shorter links?
Thanks
