Automatic Transmission shifting problems
95_Tahoe
I have a 95 Tahoe and a few months ago it started having problems with shifting after gears in Drive. I was able to pull out a fuze and reset everything. That worked until today, when I put it in drive and pulled out I had no power. It was almost like I was staring out in 4th not first.
I took it to a transmission shop thinking it was time for a rebuild. The diagnostic scan showed my transmission was running perfect. I asked if maybe it was the transmission solenoid's but I was told it wasn't.
Does anyone know what else it could be? All my fluids are fine, no odor or anything.
Please help!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
does this match your problem?
Transmission goes into gear but feels very sluggish like the brakes are on, but it will roll easily (starts out in 4th gear), you manually shift to 2 to get it moving, once it's moving you put it back in OD and the car shifts 3rd to 4th on its own and locks the converter at the appropriate time.
Shift B solenoid failed. Or a wiring problem from PCM to Transmission.. or PCM.
95_Tahoe
Sort of. It starts out in fourth I think and never switches gears on its own. I have to manually do it.
I replaced the ignition module and still having the same problem.
SunlitComet
OBS Jedi-Do Good
then that leaves a Vehicle speed sensor, Throttle position sensor or a goofed up pcm.
do you have access to a scanner that can read live data?
95_Tahoe
How do I check those?
I replaced the ignition switch and learned that the vehicle will run right for a few turn if I disconnect the battery. But then after it sits an I try to sart it again it goes back to having problems.
SunlitComet
OBS Jedi-Do Good
Generic GM Automatic Transmission Codes
Without Onboard Diagnostics (OBD-II)
Code
Problem
Code
Problem
21​
TPS circuit
66​
3-2 Control solenoid circuit fault
22​
TPS out of adjustment
67​
Torque Converter Control (TCC) solenoid circuit
28​
Transmissionmission range pressure switch
69​
Torque Converter Control (TCC) stuck on
31​
park/neutral switch
72​
Speed Sensor (VSS) circuit loss Transmissionmission output signal
36​
Transmissionaxle shift control (3.8L)
73​
Transmission pressure control solenoid
37​
brake switch(4L60-E Transmission)
79​
Transmissionmission fluid temp high
39​
Torque Converter Control (TCC) knock sensor shorted(4.3L)
81​
Transmissionmission 2-3 error
58​
Transmission code-TTS temp high
82​
Transmissionmission 1-2 error
59​
Transmission code-TTS temp low
83​
Torque Converter Control (TCC) solenoid circuit fault
How to get Trouble Codes
Turn ignition switch to OFF position
Locate Data Link Connector (DLC), see image below.
Jumper the A&B terminals(a paper clip or a jumper wire work ok)
Turn Ignition switch to ON position.
Count the flashes on the "CHECK ENGINE" or "SERVICE ENGINE" light.
FLASH, pause, FLASH, FLASH = code 12
NOTE: Some 94 & 95 models do not have the B terminal. In which case a scanner is required.
NOTE: Some 94 & 95 models that DO have the A & B terminals still require a scanner.
All vehicles after 96 are OBDII,and require a scanner to access them.​
12 Pin Data Link Cconnector (under dash)
A - Ground F - Torque Converter Control (TCC) B - Test Terminal G - Fuel Pump C - Air Injection H - Brake Sense Speed Input E - Serial Data M - Serial Data
---------- Post added at 06:36 PM ---------- Previous post was at 06:35 PM ----------
the connector should be under the dash near the steering wheel.
95_Tahoe
Thank you for all your help. It is greatly appreciated.
But the scanners can't read any of the codes, and I replaced the EPC, filter and changed the fluid and it still won't run right.
The Tahoe is now stuck in Limp mode now matter what I do. Disconnecting the battery doesn't fix anything now.
SunlitComet
OBS Jedi-Do Good
limp mode is a tranny with out power. does the tranny gear selection indicator light up one notch forward of the lock position of ignition switch?
SunlitComet
OBS Jedi-Do Good
then withe key in same position look for system power on the pink wire cavity on tranny plug cavity "E".
Inline Harness Connector C122 Engine Side
this is from a 1999 tranny but wire location should be the same although plug shape might vary a bit.
A/T Inline Harness Connector End Views
83390331
traveler613
