denalilex
hey all -
i’m new here - well, first time poster - long time lurker. which - btw - thanks for having assisted me in the many projects/repairs i have already completed on my truck. ***sorry for the length… i’m no cliff notes extraordinaire***
a little back story -
i was given this truck for free after having come home to PA from CA to visit for my twin brothers funereal… no where in my plans was the one where i’d be staying. but one thing led to another & i did & i wound up leaving my 2015 tahoe in california. low & behold - being truck-less for months , & knowing a thing or 2 about cars myself - someone was going to just give up on this & offered it to me so i took it.
that being said - the problems are many. but as i know my way around cars - labor charges are not of any concern to me & it’s many, many times more affordable for me to embark on than someone else.
& worst case is - i’m back to where i was & there were no promises it’d be perfect anyway.
it is a 2007 gmc yukon denali 6.2L v8… & it has all of the standard 07 year/model issues that you would think of when thinking of this truck. but the one i’m posting here about today is the auto ride / z55 suspension. this truck does run & drive very well. most of what’s wrong are the parts & systems that are not even supposed to last nearly this long & i have no issue with repairing as they have done their job & then some.
i don’t know how many previous owners this truck had so as for previous work - i have no clue. i’m blind on that one. i can only tell you what i’ve been able to figure out myself.
i do know it was converted to delphi gas shock absorbers in the front & the auto ride has been deleted / tricked because on my scanner it throws no codes. when it should because my compressor isn’t working. the only code i get is a short to ground. … rear driver is torn in half. so that’s bad. the fuses all work. the relay i plan to pull today to test.
if the front is converted would it typically be assumed the rears are as well? & would it make any considerable difference to convert back to stock z55? or is the gas conversion a suitable system? & in order to get this working again - any pointers on where i should begin? i plan to replace both rears as they look old & dated. i plan to also replace the compressor. with this system i’m assuming it is powered by the same compressor that powered the z55 system? the same stock compressor is still under the truck, i’ve taken a look at it but have yet to pull it. sorry, i’m not too familiar with the air ride systems. i’m teaching myself as i go. any tips would be super appreciated. & anything that ive left out that you need to know - please ask … i will answer any questions.
this is considered a rebuild. upon scanning it there are 55 codes currently so there are quite a few projects … so really, any suggestions about typical issues with this truck etc etc. thanks again!
lex
*sorry for the novel, everything seems
relevant & im bad at summarizing*
lex
