Hey guys, I have started to tow my 3 series to the track and need to get some opinions on fixing the airride in my fathers 2004 Escalade Ext- AWD. The truck has 109k miles, which I am assuming is all original suspension.
The compressor no longer kicks on (fuse is good), and the bags are deflated to the touch. I think what happened is either the sensor was bad, or the bags had a leak and the compressor burnt out. The back sags quite a bit pulling 5k lbs.
I know there are options to convert the air suspension to a stronger coil spring. Looks like it runs about 600 dollars. I also have found some sources for a new compressor and shocks/struts for aroud 750-850.
The truck goes into the dealer on tuesday for some open recalls to be taken care of, and we requested they diagnose the air ride while it is there. I will be doing the labor myself in the garage, does not look very hard at all.
What would you guys recommend is the best for towing? I am not looking to lift the truck at all, this would not be okay with my father. I am fine with either option, just want whatever is best for towing, without sacrificing too much ride quality. Let me know your thoughts, thank you guys!
