Hi all, I'm new here and am looking for a bit of insight on the Autoride system equipped to my 2004 Yukon XL Denali.
Recently, I got the "service ride control" message and had the problem scanned out to be the exhaust valve. I took off the compressor and found 1 of the wires to the exhaust valve had corroded. I soldered in new wire segments, put it back together, and reinstalled it on the truck.
The good news: the compressor now kicks in for a few seconds on startup and I have no "service ride control" message.
The bad news (& part I don't understand): The rear air shocks have no pressure; However, the compressor only turns on with every key cycle.
I plan to replace the shocks (they look worn and I already have a new pair), but i'm wondering if something else is wrong with the system since it doesn't try to inflate the shocks when driving.
I think it has a new Arnott compressor, since it has a label saying "tested: 9/31/2013". I'm assuming the previous owner changed it just before I bought it in December.
To sum-up, the main problem is the system doesn't try to inflate the rear suspension. I've read about an ALC Trimset recalibration and i'm wondering if that would fix the problem.
Any help is greatly appreciated. Thanks!
