Aux cord install on original Bose radio
HiHoeSilver
Away!
Chicago
Thank you.
Sorry, buddy. I forgot all about this. Here's what I used. It's a 5 pin jack so you can see how it switches from one source to another when you plug in. This eliminates the whole "bleed" issue.
mattt
Thanks for the pic. That looks like the only I used. For some unknown reason, I am getting bleed thru of the XM signal. Apparently there are differing versions of this jack and some are better than others. Thanks again.
Mini
I just installed ISimple and fished an aux jack to my center console. Works perfectly. From what I read about hijacking the XM lead it seemed like you had to do some soldering. Really like what I went with because its plug and play.
stevenfu
