Avh-x2600bt Pioneer
David Paul
Central NJ
Your missing the turn on for the stock amp. Again it's a blue/white wire. You may have the wrong wire harness adaptor. I just did this to 2 tahoes with Bose and both had the blue/while.
R
Rebelmyers
Pure sarcasm. I can take pic in the morning. On truck adapter side I have a blue but no blue white
YukonXL04
The Riverboat
Arlington, TX
Sometimes you have to tie into a pink wire I believe? And sometimes you have to go straight into the turn on wire at the amp...
93blkongreenpro
I think it is pink as it was on my old 01 slt. And yes, I took the remote and tied directly into it to turn on the oem amps
Sent from my SM-G935P using Tapatalk
S1nemesis1s
I know when I bought mine from Crutchfield I had to buy a harness/kit that allowed me to keep chimes and would work with my bose. I am not a radiohead by any means. But their kit made it sooo easy. Might want to chat with them and see what they think. Tell them everything you have and go from there. They will be able to steer you towards something.
My 04 with bose needed this:
Crux SOCGM-17B Wiring Interface
Install an aftermarket radio and retain safety chimes and Bose® amplifier in select 2000-13 GM vehicles
Item # 249GM17B | MFR # SOCGM-17B
https://www.crutchfield.com/p_249GM17B/Crux-SOCGM-17B-Wiring-Interface.html?search=249GM17B&skipvs=T
Eli B
Western Massachusetts
If you have Bose you'll need the integration harness (find at Crutchfield). If no Bose all you need is to jump the pink wire to the dark blue fatter wire this is the problem many people run into. ALSO regardless of Bose you must buy the mircobypass for that unit if you want to use 75% of its features. It's 11$ on amazon and truly easy effective. I have that same unit which I purchased with the dash conversion from Crutchfield. It's a fantastic unit but pioneer Dvd head units must see a pulsed ground so you can't tape that green wire to the chassis. Had a lot of fun with this install as well as every speaker including the sub. Any questions just ask.
S1nemesis1s
This exactly, I think you have the wrong harness, check out my link or contact crutchfield exactly - my link is in my first post to you. AND you do need the bypass, soooo much easier than hooking the parking brake wire up...plus it gives you all the options you need all the time..:D! Here is the amazon link to the bypass:
https://www.amazon.com/gp/product/B00A9AQPUU/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
This worked perfect for me.
