Looking at the website it looks like it includes the tis2000 software in the package. Will I need to install this on an XP machine in order to reprogram a new airbag module to my truck or am I able to do that from the Tech 2 handheld unit?
you can do it with the tech2 alone, no software is neededLooking at the website it looks like it includes the tis2000 software in the package. Will I need to install this on an XP machine in order to reprogram a new airbag module to my truck or am I able to do that from the Tech 2 handheld unit?
Thanks so much for the explanation - the website is a little confusing. Glad to know that the Tech 2 will be all that's needed for most applications. Now all I have to do is find a good used airbag module.I bought my Tech 2 from Chinacardiags.com. Everything went perfect on the purchase.
Came quick.
Others have shown TIS2000 will run on tablets and other laptops with later operating systems.
There is an adapter that will allow the computer/tablet to connect with a USB/Bluetooth dongle that plugs into OBDII port. The old Windows XP is only a requirement for use of the old-school cable connector the system was originally configured for.
While nice to have the software as an option for possible future use on a tablet... The TIS2000 software and computer are not needed for most all diagnostic and programming functions. The Tech 2 can do almost everything you might ever need.
Go ahead and order the Tech 2 with the appropriate (GM) version of the TIS2000 software, so you'l have it. But you won't need it for most operations.
Tech 2 may be able to get in deeper to identify specifics on what the problem is.I had my airbag light come on and service airbag on my 2005 Tahoe too. We had no Spring weather and temperatures went from 50’s degree Fahrenheit to the 90’s overnight and that’s when it came on. Tahoe always parked in garage and do not see any water damage under the seat being dry, but garage was very damp from the winter. Have a Foxwell NT 630 Plus and reading this looks like time to get a GM Tech II. Got codes B0100 and B1001. B0100 says electronic front end (sensor 1) performance B1001 says option configuration error. Very generic and have a feeling the GM Tech II would give more information. Does anyone know if it would?
Disconnected the battery waiting so the airbag did not deploy and read sensors located under by radiator support. Also read despite them having different part numbers can swap them for a test and pull codes again. Swapped them after cleaning contacts and inside of connectors, but didn’t think of wires going into connectors being a bad connector. Connectors did look very clean and wires did too. Pulled codes again and hoping for just sensor 2, but got codes for sensor 1 & 2. Now I am stumped and read and not sure what I read is correct and their are more airbag sensors then just those 2 by radiator support. Anyone know are their more sensors reading bumper and frame with those codes being generic indicating left side.
Wanted to add had new tires put on about a month ago and will look to see if they nicked a wire somewhere and not in any accidents.
Any help would be appreciated where to start looking next.
front impact sensor going bad is very typical, either replace one and try the swap again or just replace both, usually when it says front impact sensor it's gamble if is it left or right, not sure if a tech2 would tell you any different or not. disconnecting the battery for it is not like trying to clear a obd code, srs is not obd, neither is absI had my airbag light come on and service airbag on my 2005 Tahoe too. We had no Spring weather and temperatures went from 50’s degree Fahrenheit to the 90’s overnight and that’s when it came on. Tahoe always parked in garage and do not see any water damage under the seat being dry, but garage was very damp from the winter. Have a Foxwell NT 630 Plus and reading this looks like time to get a GM Tech II. Got codes B0100 and B1001. B0100 says electronic front end (sensor 1) performance B1001 says option configuration error. Very generic and have a feeling the GM Tech II would give more information. Does anyone know if it would?
