Mine comes on when in reverse automatically, and i can also turn it on when i want while driving.
I got power from the reverse signal under the drivers side, i have a post about it somewhere, omar helped me. Its in the panel that you unscrew by the brake pedal. But i have aftermarket radio also.
Okay, finally going to wire in my reverse camera, and move the ground while i'm at it. I've been putting it off for too long. Tahoewhat Is the camera getting constant power? From your post it sounds like you got a wire that is only powered at reverse, in order to use the camera anytime doesn't have to be constantly powered? I know the head unit needs to go to the reverse powered wire in order to know to switch screens, but where does the camera get power?
What if I spliced into the blue remote wire to my amp? That would have power at the same times you are talking about. Or would that mess with the amp?
Okay, I hooked everything up today and it worked okay after the first time I started it, but since then the camera stays on the entire time and I can't change sources on the head unit or use any buttons. My only thought is that I spliced into the wrong wire on the BCM but I checked it with a volt meter.
