Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
i should look into that..because ive noticed lately that i feel it more when i start moving, and when i come to a stop..hmm i did drop the shaft when we worked on the trans so maybe ill pull it out and see if that stops it..
it was the ****** trans mount on the x member..i forgot that we unhooked it on the top mount,not the mount through the xmember..the top is metal and the trans is metal so tahts where the noise was coming from..i got a few turns out of each bolt and now its solid..so glad it was an easy fix..
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
