westman995
- Joined
- Feb 6, 2011
- Posts
- 99
- Reaction score
- 0
I have a 97 Yukon 4 door 4x4. 4 wheel drive seems to work fine. However whenever the 4 wheel drive is engaged the front end is pretty loud and does not sound right to me. Its hard to explain the sound but it sounds like humming or slight vibration maybe?
And now just a few days ago I can hear it like clunking or something when I step on it. It does it much worse when I am turning. These noises ONLY happen when the 4 wheel drive is engaged. Is this more than likely a bad cv axle?
I also suspect that the front axle seals are leaking. I see grease/oil by the seals that looks like it flies out of the shaft when its spinning. How hard is it to replace both side seals and axle shafts?
Am I better off just replacing both shafts or should I just do the one that is making the noise? I suspect it to be the drivers side as that's where the noise seems to be coming from.
