Bad knock out of nowhere! Please help
Basshead21
I have a 2010 Tahoe LT Z71. 165576 miles on it. This morning everything was normal then get halfway to work and it’s knocking ridiculously. I checked oil level and pressure and they are good.. any help is extremely appreciated! Thank you.
Depends on where the knock is Cody. If up top, it's likely a collapsed AFM lifter. This repair can be done at home over a weekend for someone not too familiar with wrenching or in just a few hours by a pro.
B
Basshead21
Sounds more at the bottom. It’s pretty crazy it was fine this morning and then out of nowhere it was loud.
Well, it happens, kinda soon though. Get a long extension or breaker bar or mechanics stethoscope and probe around until you find where it is. If it's a rod bearing, you'll need to rebuild the short block or replace the motor.
B
Basshead21
Not much to go on here Cody, More description? One of those handy cell phone recordings?
that’s what I was afraid of . Thank you.
wjburken
Eastern Iowa
Welcome to the forum. Wish it was under better
Does the noise change with engine speed? Did the Service Engine Light come on? I am assuming it is more of a tapping sound as opposed to a squeaking sound.
Agree that a video with sound would be nice.
The first thing that comes to mind is you have a lifter that has failed. This is a common issue with these motors. Another possibility is a broken valve spring which is also known to happen, but is not as common as the lifter failure. I am assuming that you have AFM/DOD still active on your vehicle where it switches from V8 and V4 mode.
How comfortable are you with working on cars?
B
Basshead21
I’m trying to upload the 13 sec video tats to big.
B
Basshead21
With speed it’s faster and no check engine light. And yes I do have that AFM/DOD. I believe I could do it.
Champ74
