Bad knock out of nowhere! Please help
wjburken
Eastern Iowa
He did. To my eyes, this is the first account we have of someone driving around for an extended period of time with 8 quarts and did not report any damage in doing so. Good to know!
Wow. It did not register with me that he had been running long term with 8qts. I mean the words were there but .....
That’s also the first I’ve heard of anyone doing that intentionally and not having issues.
pwtr02ss
Tennessee
I put it off for over a year because I was afraid to do it (lifter rattle at start up), even though I witnessed it first hand on our shop truck. Like I said, I've put over 1k miles on it since doing it and 99% of those miles have been on the interstate. I'm not saying I recommend doing it but at the same time, it seems to have fixed the issue. I'm sure something else will break eventually (190k miles) and I'll fix it all at the same time (transmission failure, lifter failure, etc).
Kraig
As a side note, I can assure you the motor will run with 17+ quarts of oil in it—it will smoke like crazy, but it’ll run. I’d be willing to bet 8 quarts isn’t in danger of even getting close to the crank whilst running.
kbuskill
NE. FL.
Now you have our curiosity peaked so I'll bite....
How do you know???... lol
Kraig
I bought a 4.8 Tahoe at auction. When I got it home, I pulled the dipstick and thought “nah... couldn’t be that full. The tube must be full of sludge or something.” Fired it up and there was LOTS of smoke. Then I drained the pan into my 5 quart pan. And again. And again. And some more... It smoked a lot less after that and then stopped and it’s still going at over 310k miles.
Derick
Indy Suburbs
Check the torque converter too.
I was sick thinking I'd have to replace the 6.0. Turns out the Tc was crapped out. It sounded like hell too, all gears, and changed with revs. Easy enough to check out too with the inspection place coming off.
So My 09 Yukon just started knocking last week. I was hoping for lifters or something lesser but the more I'm reading, the less confidence I'm having. The knock is consistent with rpms and acceleration. Check Engine and Stabilitrak flash at 2500 rpms, then rough idles for about a minute or two. I've changed the oil and added Marvel Mystery. It's quieted the noise slightly, but I'm still concerned.
jackkk
