Bad squeaking noise
Datruckdriver
Datruckdriver
Well, I still stand behind my recommendation of the stethoscope or take to a shop and have diagnosed while on a drive on rack.
I appreciate your recommendation. I’m pretty sure I’ve seen a stethoscope in our shop at work. I’ll try to find it tomorrow and see if I can’t get one of the guys at work (or my 7 kids
) to bounce the Yukon around for me.
Check the steering system components and the bushings that secure it to the iframe.Check the hub on the side that hit the curb. You might have bent something causing the bearings to squeel. Jack that side tire up and see if there is and vertical or horizontal play.
I looked everything over and all seemed to be ok, but I will jack it up and check for play in the left front and rear. I hadn’t thought to do that. Thank you!
olyelr
Elk Rapids, MI
3.5” body lift? Ive never heard of one higher than 3”.
I would also check the body mounts…maybe something loosened up enough to allow some minor shifting, leaving a puck or two in a slightly different spot causing a minor squeak.
Also…ive never seen flares like that before on this body style. Custom?
Autopat
