Bagged the tahoe
jdpber
GOLD MEMBER
The America
Well boys and girls the Tahoe is Bagged.. TOW bags that is..
last night i did the install of the Air Lift bags. i would rate the job a 2:10 as it was not that hard and did not take that much time.
i started by deflating the bags. then i jacked up the rear of the truck a couple inched to spread the coils a tad wider. then it was a balancing act of USING HANDS ONLY to feed the bags into the coils.. once in there are 1.5" heavy rubber mounts for top and bottom.. then i carefully routed the air lines to the 7 way outlet where i drilled 2 holes for the valve stems.. and installed them at this location.. simple and clean.. i plan to add a viair compressor and tank and regulators in the near future, but for now this will work perfect as i can grab air at any gas station or at the house out mu large compressor..
overall at 30psi i can have the rear about an 1.5"-2 higher than the front. but at 5-8psi i am deal level with front for every day.. so i can gain a few inches when it squats with a trailer and air up and be level..
towing the camper with bags and the stabilizing leveling sway hitch should be a dream now.. nice and level and smooth..
i have a 600 mile camping trip in june that will be the true long distance review of the ride quality aired up and towing about 4k loaded.
overall so far i am very happy with the ride quality..
CHOO CHOO
BackPagePhil
Manheim, Pa
Damn that looks good. Love your tahoe man....
Sent from my DROID4 using Tapatalk 2
jdpber
jdpber
GOLD MEMBER
The America
Damn how did you get it up that high? What set-up do you have?
im running a Trail master 6" suspension lift.. i called up Air Lift with the dimensions of my rear coils and had them make a set of 2,000# bags for my specs.. tires are 35s on 20s..
soon i will be adding: tank, valves, regulators, and a viair compressor.. horn also most likely i mean why not..
edgaranah1
Corona California
And those towing mirrors complements the Tahoe well. Damn wish I had the money to spend on a suspension lift and 35s
yates ™
Resident Apple hater
Iowa
I am done helping you if you are adding train horns.
M Hankel
Vancouver, WA
Truck looks good man. I'll bet those bags will really make a big difference in stablizing when towing.
Mike
Administrator
Man that is awesome!! Have you ever though about taking off the side molding and colormatching the handles? I love what you've done to Le Tahoe so far :)
jdpber
jdpber
GOLD MEMBER
The America
lol.. doubt the wife will let that happen anyways.. for now Freeway blasters work fine they are 130db.. plus cant justify the moneys for T horns i would like..
Administrator
Shoulda installed train horns on Le Crayola when you had it :lol:
browner010
