Bags on Lower Control Arms
robb.
dallas
so its about puttin the bag in a certain location on the LCA for the desired right height without the bad camber?........just the bags and no shocks?
MOB what's ur ride height look like?
MOBmentality
Has a $25,000 Punch
NO positioning bag has zero to do with camber.. you still just align it like a normal vehicle..
Bag position effects:
:: travel (the closer you are to the pivot point the more movement you get)
:: ride quality
:: psi required to lift (the further you are from the pivot point the less psi it takes to get the truck up)
But not camber
You can align your truck to have a good alignment at ANY height.. some heights take more parts and work than others.. but.. you can align it to sit at any ONE height...
Its the same as aligning a static drop truck...
SO if you aligned it to be perfectly aligned at -5 in the front.. its NOT gonna be aligned dumped.. OR lifted... this is why alot of DDs have bad camber dumped.. because.. why in the hell would we want it aligned dumped.. when its NEVER driven that way?
My alignment was st at about -4 in the front.. but i ususally drove it around somewhere between -3 and -6 depending on the roads and what i was doing...
Some bags dont require shocks.. and some do.. thinner bags need shocks more than thicker bags.. alot of people say the 400-600psi bags already act like a shock. i had shocks on the rear but not on the front of mine.. with 200psi firestone 2600s in the back and 600psi SE 2500#s in the front
thor1125
orange county
hey airbgd....
did you ever install your bag set up yet? im looking to do the same thing as well.. what slam bags did you go with .. i noticed there are different sizes in height... and since i order everything through avsontheweb.com because i get it at wholesale cost i need to know what size bags your running.. also pics would be nice to . thanks .,
Wilk 2003 tahoe
