barn door hinge pin
qukon 95
Has any body found the barn door replacement hinge pins? Mine are worn pretty good
I don't want to find some used good ones unless I have to.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
gm 15645336 for a pin, gm 15995442 for a bushing.
---------- Post added at 09:17 AM ---------- Previous post was at 09:16 AM ----------
about $3 each online typically. price at dealers will vary.
95escahoe
And the bushings were changed its alot better then the ones on my 95 were
Sent from my HTC One X using Tapatalk 2
qukon 95
qukon 95
thanks sunlit!!! for all the parts $42.78 dam forgot the co. name
just that fast.... i will post the co.
NOW how to get the rusted pins out?
yukon985
did you ever get these pins out? i need mine out right now!!!
qukon 95
qukon 95
Yes! I did just the pass barn door and I had to use grinder to cut the pins then punched them out
They still was a pain to get out. Now there's no play at all in the hinges.now to tackle the driver side.
Alexander
Kiev
my lower door hinge van side is so badly damaged that i need a new hinge. the part where it holds the pin bushing is no longer a circle, its broken and in the shape of a "C".
how hard is it to repair/replace these hinges? i see they are welded in.
mhessick
