JochenWoern
Although I'll agree that cold weather plays a big factor in killing batteries I will contest that all batteries are the same. Just ask Consumer Reports. If I were you I'd go for a good high CCA battery. I prefer Exide Nascar Extreme 9 year batteries. Their CCA is up there and the battery does cost a little bit more, but I haven't had one come back on warranty yet. I figure it's like a light bulb. Put a high watt/amp/volt bulb in a low draw socket and it'll last much longer than it's made to due to the electrical draw being lower than designed for. This is where over-engineering helps out a lot.
Sent from my myTouch_4G_Slide using Tapatalk
+1
