Before and After
ShawnQ
Bayou Vista, TX
Looks good. I just got a set of 20x9's with +14 offset...and looking to get 305/55R20s as well (Nitto Terra Grapplers also).
Hopefully mine wont rub too much as I'd rather not mess with the metal. I don't mind trimming plastic, but would prefer not to mess with metal.
Any reason why you went with the Top Gun kit over CCM, Rough Country, etc?
I notice a lot of people here use CCM...but it seems the Rough Country/Top GUn style kit is easier to install and cheaper...
ShawnQ
Bayou Vista, TX
Where did you get the 3/4" spacer?
I can only find 1" and taller...
I'd like to get a 1/2" or a 3/4" rear spacer when I get mine done.
Thanks,
Shawn
DTHOE
Has anyone ever used a Pro Comp Leveling Kit? It has the same 2.5 inch lift in the front and a 1 inch spacer in the back to get rid of the Cali lean...
Is there any difference between the Pro Comp and the CCM lift?
boudreaux
Atlanta
Are you guys installing the leveling kits yourself, or having a garage do the work.
If using a garage, about what are you paying for this?
Wakinvol
East TN
They can be done yourself...nohing but time (a few hours). I did mine and took it off myself. No major issues. If I did it for someone I would charge $110-125 probably.
fullyauto12
