Belltech drop w/ autoride and no spacer in the rear? Questions...
KMeloney
KMeloney
Do the links need to be straight up and down? Do i need to move the lower part of the link closer the the front of the vehicle in order for it to be completly vertical?
Nevermind i just saw that the air ride links are centered by a bracket and it is welded in place so you would not be able to slide them on the upper arm.
It's funny you mention that mounting point on the arm. I wondered if that could be moved to allow you to shorten the links more than the current shortest length feasible... You say it's welded on? I thought, at first look, that it was just clamped on (and bolted at the top). I didn't know it was welded on.
gordo214ace
