Conor
"Bob's your Uncle"
All this air ride stuff is confusing the shit out of me.
yep, they came with my springs. i think the mcgaughys kit tells you to just bend the factory ones though. they connect to this little rocker thing that moves up and down depending on the height of the rear.
normally if your truck is sitting lower its because you're towing or carrying a heavy load. so they kinda tell the compressor to raise the truck because its too low. using the shorter rod makes your truck think that the lower height is the correct height. if you dont change it or bend them gonna raise the truck to the normal height.
Uh oh, thiis may not be pretty, we had a similar vendor issue a few months back with spindles.
