Belltech suspension ..
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
I run beltech in mine. No problems. I did the lowered front spindles instead of springs though
HiHoeSilver
Away!
Chicago
guy from norcal
Spindles help keep your suspension geometry the same as stock. And rides much better.
I would stay away from springs,Lots of negative reviews about they ride like crap.
Hit up norcal SS. he sells all the goodies you need.
sumo
rhode island
It keep your suspension same as stock. It won’t change angles of your control arms, axles if you have 4wd. Won’t change the ride as if you were to use lowering springs and also eliminate the need for camber kits to correct offset camber of lowering springs.
download
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
pm me i can help you out with the set up. i also have the endlinks/bumpstops for the free and i highly suggest you google tahoe free travel mod. I would cut off the rear bracket for sure
DABb
