best brake upgrade
shundal
NorCal
Anyone who has baer eradispeed +1 kit have a problem with the pads not being all the way down on the rotor? I have that problem both front and back. I know the kit was made to be on several vehicles, but this is a real problem for me...
I havent noticed this issue, however a few weeks ago i noticed a grinding noise coming from the front breaks. Had it checked out and the inside brake pad on the passenger front has completely worn down and grinding the rotor. Rest of the pads were wearing fine.
Hamrdwn
Lenexa, KS
I to have the Baer system only on the front of my Tahoe and the pads do not utilize the full face of the rotor. I suspect that it is really set up for a larger caliper as well. I went cheap and kept stock calipers and Greenstuff pads. Works great. The only issue was the sway bar end broke when I was seasoning the rotors and bedding the pads. Man that thing can stop now. Great brakes for under $600.
Freedom Motorsports
R1Concepts...
And getting them from a Site Vendor so that you have support at your finger tips.
hmp2037
