Best hose pinch clamp for fuel line?
Matthew Jeschke
Sahuarita, Arizona
Ah H E double hockey stick! I broke down. First time EVER I've been unable to get my vehicle to move again and had to call a tow truck. Lost fuel to engine, my wideband would fire up at 15:1 then quickly go to 20:1 and engine would stall. Probably surfaced yesterday where it stalled on a mountain road. No big deal I got out and we walked for an hour, came back and zero issue. Ran like a top again. I assumed my engine tune didn't like 4700ft elevation I was at. It was a long stretch but seemed feasable.
Got in it to drive it again today and it did same thing. Only this time I could start it but it would be at 20:1 AFR and no power to move vehicle. Not that I should at that, it'd probably burn the engine up. I got a tow back to my house.
So long story short, it's possible a hose clamp came loose in my fuel sending unit. I swapped the pump with a high flow aftermarket pump and they sold me screw clamps for the fuel line HERE. Today I immediately suspected the pump and called my friend who recommended putting that one in. He immediately said it's the screw clamps and I should have bought factory style pinch clamps.
For my question...
What brand pinch clamps are good for the fuel line in the sending unit?
I'm running the pump HERE. I have a 57 PSI fuel pressure regulator (up from 45 PSI another long story).
I'm also using this fuel hose HERE
My head is also a bit dizzy trying to figure out clamp size. ID of hose is 5/16" OD isn't spec'ed. When I measure OD I get around 1/2" (should be larger when I slide it on the pump). What size clamp would that be?
Scottydoggs
NJ
mine did this but after it stalled out it would only come back to life after it sat a hr or so, then run for about 10-15 minutes and die again. fuel pump was dead.
so gear up for a tank drop.
Scottydoggs
NJ
Yeah, I had also thought the pump might be dieing. It's an AEM high flow pump. Maybe has 1k miles not much. I just put it in a couple months ago.
if a hose off the pump inside the canister popped off i doubt it would re start for any amount of time. pumps sadly do just die, so maybe theres a warranty on it still? most give ya at least 90 days.
Waiting_to_Dye
