Best lowering kit
lowslo
What is the best lowering kit or parts to lower a tahoe? I want to go as low as possible but I dont want any camber issues.
ghost
Senior Member
do you have a budget? theres a few diferent things you can do. but i sugest going 3" drop arms in the front. no camber issues and rides like factory. now the rear is a dif story. a lot of people like the tb drop coils that norcal sells. i had the older djm ones and didnt think they rhode very well at all and i had them matched with djm cal max shocks. i still cant seem to find anything im satisfied with.. just my 2 cents.
im currently using beltech spindles and keys in the front for a nice amount of drop and it rides really good. im using 19.5 cal max shox in the back with cut 3" eibach coils, and it rides better than when i had the 20.5 cal max and djm tb coils...
L
lowslo
You got anything lower? Our will I have to piece that together?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
How low do you want? i have kits that go lower ie 4/6
L
lowslo
How does it ride and is there any camber issues?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
well in front it will be
keys/spindles/shocks/camber bushings and your done there
in rear will be djm hardware kit/belltech springs which you will be able to cut/and new rear belltech shocks/new bumpstops also since you cut the brackets off the frame
WIth the rear cut springs the truck actaully rides good because your only cutting off the dead coils.
You can add airlift helper bags inside the coilsprings when they are cut and aired up to 35 psi you can load 6 people in back wiht no issues.
Isaiah1209
