Best method of changing transmission fluid
blueflamed03
Oklahoma
Have a tranny shop do it. They can suck out the old, take tranny pan off for visual inspection, and replace filter, then add new gasket, new fluid.
yooformula
Milwaukee, Wi.
depends on your miles imo. I wouldnt flush if you have alot of miles on there. My 03 has 160k and I dropped the pan, wiped it down, replaced filter then refilled. Very easy, the hardest part was bending the trans cable bracket over a bit to pull the pan out.
blueflamed03
Oklahoma
sorry, I surely didn't mean flush, I meant suck out old, which includes TC, which dropping the pan, you don't get the old fluid out of the TC.
thunderii
thunderii
Anaheim CA
the shop offers 2 diff ways to change oil IMO. My truck has 67k. is flush okay or should i have them drop the pan and change
bigpapapete
nova scotia
I really don't believe in flushing the trans ever ,but thats my opinion and mine only. I think that it stirs up any deposits and may move them to another place you dont want . drop the pan change the filter. that will tell you if you have a problem , dposits in the pan.
thunderii
thunderii
Anaheim CA
this is my first time changing T/F on the truck and I'm the first owner. I had bad experience changing T/F I broke one of the bolt trying to tighten too much. I'm bit wary to do it again. :(
kendrick newborn
