Best real HID option available?
UofMZ71
yeah im sure thats the right harness, the website has changed and for me i had to do a search for the harness and add it to the cart, but its the same price and i dont see why they would give you the wrong harness, so go with that. and you dont need the error eliminator.
Conor
"Bob's your Uncle"
Seattle, WA
DDM is not very helpful when it comes to trucks. They specialize more in German imports. All you need is 35 or 55 watt ballasts and H11 bulbs for lows and 5202 for the fogs and a wire harness. You do not need an error eliminator. That is for German cars. Here are the links for everything you need:
http://www.ddmtuning.com/viewCart.php
Not sure if that link will work, but here is a copy and paste of the cart:
Description Price Qty Total
HID Kit Wiring Harness
$15.00
FOG LIGHTS:
DDM HID Kit, 35W, H16, 5000K
Bulb Color: 5000K
Bulb Type: H16/5202 (+$10.00)
Wattage: 35 Watt
$50.00
LOW BEAM:
DDM HID Kit, 35W, H11, 5000K
Bulb Color: 5000K
Bulb Type: H11
Wattage: 35 Watt
$40.00
Total:
$105.00+shipping
TREYR8D
Wouldn't you need a wiring harness for every pair of HIDs you get? The harness says 2 in 2 out, but i assumed that meant for 2 bulbs.
Has anyone gone with a 55W kit in the HI Beams? may be overkill, but when i have my brights on in the back highways of NE and CO, I want to see as much as i can.
Conor
"Bob's your Uncle"
Seattle, WA
You only need 1 harness. A wire harness is not required for fogs or hi beams. The only reason you need a wire harness for the low beams is because of the auto-on and DRL feature. (DRL for Yukons)
Seel
Seel
Hook'Em
Conor, you're the bomb.com bro. Thanks for the heads up & the time spent. Owe you one.
zach2011
Platinum Member
I ordered and installed mine without a harness and they work perfectly. :confused:
Conor
"Bob's your Uncle"
Seattle, WA
Its only a matter of time. Mine worked without a harness for a month or so, and the intermittently would start to flicker on start up.
gettinbigger08
I just tried installing these on my 07 Yukon last night, hoping you guys can help me out.
When using the harness, do I want to tap both the harness and the wiring unit to the battery, or just the harness?
TREYR8D
I just ordered mine, just like that listed above, but i got 35W 6000K Lows and 35W 5000K Fogs. I like the blue tint on the headlights, and dont really like yellow on fogs. maybe i'll do the Hi's down the road at 55W 6000K? Cant wait!
Seel
Seel
Hook'Em
Can any of you guys post pics of your HIDs? That would be great. Thanks, Seel
OklahomaSideShow
