best trans oil pan(s) for cooling
gstadter
Main question is:
Looking for advice on which transmission oil pan(s) would do the best job of cooling for my 2003 Yukon XL.
points to note:
I do plan to add an additional cooler in front of the radiator at some point, but if it can only do good to have both, I'll do both.
Build quality is equally as important to me as cooling properties.(don't want to go with a style that is prone to crack or leak, despite better cooling ability)
The three main manufacturers I've learned of so far are TCI, Derale, B&M.
The two main types I've seen are fins on the bottom of the pan, or tubes that run through the pan.
any ideas or suggestions would be appreciated.
edit: perhaps it is relevant to mention that I do usually have at least four passengers with me and tow a 28' pontoon boat w/150hp engine.
Danzigman
Galveston, TX
Just get the TruCool cooler and call it done... You don't need both, and a pan won't be enough.
Big Buttons
The SS Burb
South Texas
Yea just get the TruCool 40K call it done. That's what I did and haven't looked back. And I don't go easy on my truck...
