best way to detect a stuck caliper?
cmc76
out of nowhere on Saturday I got a grinding, pulled it apart. rear drivers rotor was shot, inside pad was all metal.
I put on a new rotor, greased everything, new pads. cleaned the caliper, was able to clean it up well.
New pads and rotor are on, have not drove it hard at all, but im still getting some burning scent, minor smoke. whats a reasonable amount of time for it to settle in, before swapping out the caliper?
cmc76
cmc76
I might have been chasing an issue that didn't exist. They were getting hot, but seems to have resolved itself. Ill give it a few days and crawl under to inspect. but no more smoke, no more smell.
Kenny D
Crosby, Tx
The best way to check is to have someone operate the brakes, while you are looking to see if the caliper retracts.
The smell might have went away because the pads may have worn down enough to allow less restrictive movement.
cmc76
cmc76
I was thinking that, but its not like they are spring loaded to retract. Ive only put on maybe 30 miles with the new pads and rotors.
I will make sure to have someone there when I climb under. good idea.
Kenny D
Crosby, Tx
They will retract due to the hydraulics. Did the same for my son's front calipers on his 90. Also check the rubber brake line too, they will also mimic a stuck caliper.
HiHoeSilver
Away!
Chicago
The line could be kinked or clogged.
New pads can smell hot during the initial break in. Use the pad manufacturer's break-in procedure if it publishes one. Many times you have to look at the mfr's web site to find it.
cmc76
cmc76
i was going to look this morning, but its a monsoon. It does seem that any sign of smoke/smell is gone though.
Thanks for the ideas though guys, i will be going under to take a closer look to be sure.
tima2104
