Kee Fuller
I use the autozone ones. I live in the desert so i use em maybe 3 times a year
So why are you commenting in a discussion on which wipers are best?I use the autozone ones. I live in the desert so i use em maybe 3 times a year
1 thing I hate is bad wipers so I had to ask. I remember buying some wipers for my 04 and it didn't contour to the shape of the glass very well I had to return it
Yeah. On the NBS trucks, the curve of the glass makes the beam style wipers miss a little corner on the bottom of the passenger side. Thought about putting a heat gun on one to see if I could change it a little, but haven't gotten around to trying. I like the rain x ones.
89Surburban....... I tried a trick that worked......
I had traditional style wiper-blades on a last GMC truck. The end of the wiper would not touch the glass / outside curved window edge. I lightly touched the end of the blade, and then it touched.
I got a tie-wrap, cut it near the 'catch'.
I pushed it inside the blade holder, nearest the end of wiper ( last metal arm that you slide the blade through) and it put more pressure on the wiper end, and it worked!
Problem with the new beam wipers are, you are beholden to the shape of your glass. The end always lifts at the outer windshield.
I wish the beam had a slight bend in the spine, at the end.
