Big 3 Upgrade Directions w/ Pictures
Brandon X
Brandon X
Michigan
The chasis to engine, thats ground aka BLACK wire? I'm getting wire at work, so I'm going have black and red appropiately placed.
I'm not sure lol. It's either the negative to chassis wire or the chassis to engine block.
raptorforme93
Tampa, Fl
Do you have to use 0g wire or will 4g work? I have lots of 4g but im out of 0g. Will it make that big of a difference?
Brandon X
Brandon X
Michigan
4g will work. Anything bigger than the stock wiring will make a difference. However if you're running 0g on your system I recommend using 0g on the big 3.
Brandon X
Brandon X
Michigan
I used a vice at my buddys shop to crimp the ring terminals. It's not really the best way to do it, but it's the easiest and gets the job done. It's better to solder the ends.
AtomicHoe094
Atomichoe094
cleveland, OH
i was looking at a crimper designed for 0awg and small wire. it was like 200 bucks, but if soldering is the way to go then that doesnt cost a damn thing
detroitcadi
