Will you please explain to me what the big three is? I have no clue what you were talking about.Hello All,
I did the BIG 3 today. It was an interesting project. Used a kit I ordered from Amazon and had about 8 inches of wire left from 9 feet. I used:
https://www.amazon.com/gp/product/B0029LDIQQ/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
and
https://www.amazon.com/gp/product/B019EF1GJK/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
I ended up gaining a couple more needles past 14, hovers between a higher one and lower one. Truck seems to start quicker and the blower motor works better as well as very very little dimming when I used the power windows. Worth it if I do say so myself.
Don't mind the yellow wire (that is my light)
It involves adding large gauge wire (1/0) between the main electrical points in your vehicle. Usually between battery + and alternator +, between engine and frame (ground), and between battery - and engine (ground).Will you please explain to me what the big three is? I have no clue what you were talking about.
Did this awhile back to my trucks as well and there's an obvious difference.
Hammered all my ring terms as well and then solder - they ain't comin loose. @S1nemesis Did you fuse between the bat and alt? Just ran black loom over all my red/hot wires last night on both trucks to clean things up.
Smrtss1 - Does it seem like the wiring the 12 are 'up to *****'? It's certainly an upgrade to all of the NBS trucks with added load or not but haven't really examined how GM is wiring their newer trucks.
