Biggest tires for stock 20" rims on 2016 Tahoe???
AngelXL
I'm very interested in this recall. I have this set up with the 20" Continental.
I will give them a call tomorrow.
AppocAlexx
Darth Appocalexx
Abilene TX
If you want stock no issues and with out any upgrades needed I think the 275 60 20s would be the best bet. You may rub a bit on the rear front wheel well and a tad bit on the front lip.
Not sure who you use for you tire shop but when I worked at discount tire, if a customer was in between getting stock vs over sized tires we would do a couple test fits before they purchased the tires. May be an option for you. Not sure if other mom and pop shops would be willing to do something like that. Always a good thing to ask tho.
Fifty
This is odd. Going to be an expensive recall. They are probably holding out as long as possible so they only have to prorate tires based on mileage...
Fifty
Only effects tires with a DOT code that ends in (1815)
So check your sidewall. It will be the stamped number at the end of the dot sequence.
Mine was 1715
