bilstein hd shocks on a NON lowered yukon
franksbanks
Arizona
this weekend i had spent some time under my yukon due to a shock bolt that fell off due to me not assuring it was tight-- :Stupid Me:
history on truck
i had the factory air ride system - rear shock bags were damaged, so i replaced all 4 with the bilstein HD shocks-
on sunday, i discovered that the rear shocks had what appears to be a leak coming from the top of the shock-(under the boot cover) as if it is/was leaking the fluid out..
could this been caused due to the truck being at stock height?not lowered? i intend to do a 2/4 by the end of this year.
are these HD shocks intended for lowered trucks? i should of have made sure of this prior to installing them..
NathanJax
Vacation Nathan
Administrator
Jax, Fl
could this been caused due to the truck being a stock height and not lowered as i intend to do by the end of this year?
No
Are these HD shocks intended for lowered trucks? i should of have made sure of this prior to installing them..
They are intended for stock suspension.
Maybe it was just a bad shock or something, but if you go to Bilsteins website, you'll see they are for stock suspensions and most people use them because they are just a great shock. If you're using them on a lowered application, you need to use the shock extension so the shock sits/compresses like it would on a stock height truck.
franksbanks
franksbanks
Arizona
No
thanks for the quick reply nathan -
i checked out the website- good info
the kit i plan to get includes shock extensions, spindles, and rear springs - thanks for assuring me i didnt skip ahead and mess it all up.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
No worries. Spindles keep the front shocks at OEM ride height/compression and the rear shock extensions will do the same for the rear. So you should be good!
:Handshake:
dylansmashed
