Bilstein Part Numbers
NGAneer
NGAneer
NWGA
good to hear, did ya grind it or do it another way
Its complicated....
Grind away the rust
Wire brush the same area to get the corner where I couldn't get the dremel in.
Spray with PB blaster
Propane torch to the spring seat
Spray with PB
Torch
Then put a piece of pipe over the stem end of the shock and beat on it with the spring seat sitting on two 2x4s, that are sitting over the hole in a cinder block.
ta07hoe
If it works it works. What height did you set them at and how's it look
ta07hoe
First notch up with the existing TGC 2.5.
Looks good. What size tires? did you happen to measure the fender heights? I put mine on the third clip with my ruff country lower spacers and a 1.5" spacer in the back. It still has the same 275/60r20 good years and stock sat at f36/r38 now it's 39.25 front and rear but it seems to vary 1/4 of an inch from time to time
NGAneer
NGAneer
NWGA
They are 305/55, I didn't measure before hand but I wrote the measurements down somewhere. I think I was about 0.75" higher in the back before the 5100s.
24redDenali
