Black Bear still making fan harnesses?
YukonXL04
The Riverboat
Arlington, TX
does anyone have the p/n for the harness for the stock efans from the 04-05 yukon?
Should be a direct swap into a tahoe.... just cant find the harness
I do not have the part number, but the reason you cannot find it is because it is integrated into the whole front harness. The headlights, turn signals, horns, etc... are all integrated into that harness. The people who are using a stock harness are either buying the whole front acc harness from GM or getting one from a junk yard. Usually they end up picking apart the harness until all that's left is the electric fan portion.
bigdawg70
We offer one item tuning, which would fit your need. Shoot an email to [email protected] for further info.
Thank you email has been sent. Does anyone know if the dorman 620-653 /654 are both direct bolt ins? Do they both run the same plug. Want to order harness and make sure I order correctly.
AdamxYukon
