How?
I've seen references to a relearn procedure for the blend doors, but not the procedure itself. Any info?
From the shop manual for Manual AC:
Actuator Recalibration
When replacing the HVAC control module it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC control module be sure to perform the following:
Important: Do not adjust any controls on the HVAC control module while the HVAC control module is self-calibrating. If interrupted, improper HVAC performance will result.
Place the ignition switch to the OFF position.
Disconnect the scan tool.
Install the HVAC control module.
Connect all previously disconnected components.
Start the vehicle.
Wait 40 seconds for the HVAC control module to self-calibrate.
Verify that no DTCs have set as current DTCs.
When replacing the HVAC actuator it will be necessary to allow the HVAC control module to perform a calibration process. When installing the HVAC actuator be sure to perform one of the following:
Preferred Method (w/ Scan Tool)
Clear all DTCs.
Place the ignition switch in the OFF position.
Install the HVAC actuator.
Start the vehicle.
With the scan tool, initiate the Motor Re-calibration feature of the Heating and Air Conditioning Special Functions menu.
Alternate Method (w/o Scan Tool)
Clear all DTCs.
Remove the HVAC/ECAS fuse for a minimum of 10 seconds.
Install the HVAC/ECAS fuse.
Start the vehicle.
