Blend door issues
NFunderburk
Help! I have an 03 Tahoe and I just replaced both the blend door actuators and it still won’t change the direction of air flow from defrost. This should have fixed the issue but it did not. Any help would be greatly appreciated.
Trey Hardy
Eastern North Carolina
Should be able to pull the hvac fuse under the hood wait a min put it back start the car don’t touch anything ac should self calibrate itself that’s how I do mine in my 07 anyways the door actuator will have to be calibrated to operate properly
The driver and passenger temperature actuators do not control the direction of flow, that's the Mode Actuator.
cuttingedge
